I have a 2002 KitchedAid kuis185jss2 free standing ice maker. The machine will not stop filling the water reservoir pan. It continues to fill it to the point it overflows into the ice bin.
Things to note -
- I have tested the inlet water valve. It measures ~300 ohms, so this is not malfunctioning. It also shuts off properly when i turn the machine off or unplug the unit from the wall
- The machine does enter and do the cleaning cycle and complete properly. I ran the cleaning cycle twice using 2:1 ratio of water with CLR. So i have seen the circulation pump run.
Why does the machine not shut off the water and continue to the next cycle where the water is pumped the cold plate?
I cannot find any kind of feed back or shut off sensor. I have googled for hours and cant find anything… What else can i do? HELP!?
-Todd
