STACKED LAUNDRY CENTER;all cycles work as usual except tub not draining
I Guess I Have Either A Blockage In Pump Or A Defective Pump; Have Only Browsed Internet For Troubleshooting So Far; My Question Is Really Basic But Before I Start Ripping And Tearing I Thought I Would Ask For Some Advice; This Is A Relatively New Unit In Service For Only About A Year And Have Has No Problems Until Now; I Want To Know If I Must Remove The Upper Dryer Unit To Be Able To Disassemble Cabinet In Order To Access Interior; If So; Can Anyone Walk Me Through The Steps To Dismantle The Unit; Thanks, Any Advice Is Appreciated
I don’t know that much, personally, about Electrolux, but most stackables can be serviced by removing front panels. They are normally accessed by removing screws at bottom corners, pressing in on release clips at top corners, or removing door hinge screws (for front loaders) to remove the panels.
