Stackable washer dryer Frigidaire panel access
Photos: Frigidaire stackable washer dryer - Google Drive
Brand: Frigidaire
Model Number: MODEL FEZ831AS1
Main Symptom: replace water inlet valve
What happens & when: all the resources on YouTube are not of my model! Can someone send me a resource on how to access the water inlet valve? There is a rubber screw in the middle where the top access panel of the washer meets the front panel can’t seem to get it off thank you! The only other tabs I see are to remove the front panel, but those aren’t releasing as well
Photos / video link: I took photos but not sure how to share
Two screws on the bottom of the large front panel as in this parts list may help!
5995363560.pdf (980.4 KB)
