I recently had to pull the washer out from the dryer to replace a clamp on the blower fan in the dryer. I disconnected the electrical chord going from the dryer to the washer. When I reassembled the unit, the washer would not turn on. Nothing. No sign of electrical activity. I replaced the fuse in the front/left of the washer. I recently replaced the lid switch assembly unit. Is it possible something happened when I disconnected and reconnected the electrical umbilical chord? I would appreciate any insight. Thanks.
Bob:)
See if the dryer section will heat. If it does it means both legs of the 220 v power are working so then check to see if power is getting to the timer. You should be getting 110-20 to the timer.
