Stackable dryer temperature control
My dryer of my westinghouse LTE6234AN3 seems to be to hot for the low heat setting? t’stat problem or limit problem. my email address is [email removed]…Thanx in advance for your replies.. Ren
Replacement parts for WHIRLPOOL LTE6234AN3 COMBINATION UNITS | AppliancePartsPros.com
See the attachment for your tech sheet.
Looks like the unit was actually made by Whirlpool.
[COLOR=“DarkRed”]t’stat problem or limit problem.[/COLOR]
Could be either of these.
First I would check/clean your vent system. Also check/clean the blower wheel.
Following is one way to do this.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer’s vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
Next I would check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
Next would be the cycling thermostat (Item 42 in Section 4). You will notice that it is 4 connector. 2 of them are the actual contacts the other two are for the internal heater. This heater is turned on for low heat setting. It adds heat to the thermostat causing it to cycle more often resulting in a lower unit heat output.
Disconnect one side of the heater and measure it, should be around 4,000 ohms.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
LTE6234.pdf (102.0 KB)
