Squeaking noise on spin
Brand:Maytag
**Model Number:**MVWB835DW3
Main Symptom: Squeak on spin
What happens & when: Squeaks on spin with load and gets louder as spin increases.
I am getting this squeak, but it is running fine and washing well. Two questions to this topic. Is this an immediate repair or is this something that can wait for a few weeks? I am not hearing any metal grinding sounds. Second, is the repair worth the cost of the part and the time? This is a relatively complex repair (I don’t own a spanner wrench) so I am probably looking at least a 2 hour repair time. Thanks in advance for any response.
The squeaking is likely the transmission bearings starting to fail. The noise will get worse until the transmission possibly seizes up. As far as if this would be worth repairing, the answer varies from person to person based on many factors. This link can be used to view the transmission for this model and there is a repair video on it for reference as well. W11393685 Washer Transmission | Genuine Whirlpool OEM In Stock
