washer works great, dryer does as well, although it squeaks annoyingly. If I shake the unit, it will sometimes stop. I am mechanically numb but would like to fix it myself if at all possible…HELP!:rolleyes:
You need to look at the rear bearing attached to the rear of the dryer. We’ve replaced a lot of those in our area. Also check the front glides.
Here’s a parts breakdown
Model LCE702AWW3
Nat
so if i buy the bearing kit - i should be able to fix it myself?
thanks for the info, btw
Yes, they are fairly easy to install.
Nat
Thanks Again - just bought the kit
Wish me Luck…
HaPpY HoLiDaYs !
Good luck, keep us posted
Nat
