Sprung door on kenmore oven
door is sprung. does not close enough to deactivate light switch. trying to figure out what part to replace.
Look carefully at the door frame, if it is bent, you might try cedar wedges placed between the bottom of the door and the stove, then just force it shut. If your glass breaks, your best solution is to order a new door AP4310643, only $90 plus about $50 shipping.
So you cannot tell me how to remove the door.There is no glass on this door>
