Sprayer arms
My dishwasher has stopped cleaning my dishes properly. I have taken the arms out and cleaned them and put them back. I can see that the water is pumping in through the arms but the arms are not spinning. HELP!
Hi.
Most likely there is not enough water pressure in the dishwasher. Check if water fills to the water heater.
Next check if the filter screen at the rear of the tub is blocked with calcium deposits.
It’ s also possible that the water fills and drains.
Here are the breakdown diagrams and Body replacement parts for General Electric GSD2230F00WW Dishwasher | AppliancePartsPros.com
Thank you. Post the results.
Simon.
[quote=Simon / APP Team;735448]Hi.
Simon.[/quote]
If it is the water pressure, what do I do?
Hi.
Have you checked the things I pointed to?
Thank you.
Simon.
I have taken the arm out and cleaned it. I have also cleaned the filter.
Hi.
What is the water level after the fill cycle?
If you add 4 cups of water will that improve the wash?
Simon.
It does not fill up with water. It drains is draining as it fills up.
My last post was unclear, I apologize! If I pour water into the bottom of the tub, then water will start coming out of the arms. But then all the water drains out and it is not able to pump more water in. It is like it is draining at the wrong time if that makes sense.
HI.
Open the toe panel(4 screws) and check if the drain solenoid is stocked in lower position. If it’s corroded due to the water leak from the shaft seal then you need to replace the pump and motor assembly.
If there is no water leak - replace the solenoid
[PART]WD21X10060[/PART]
Here are the breakdown diagrams and Replacement parts for General Electric GSD2230F00WW Dishwasher | AppliancePartsPros.com
Simon.
