Spray Water after Last Spin
After last spin in washer cycle, the washer sprays that re-wets clothing
The machine probably has a feature that sprays the close before the final spin to remove soap suds. It sounds like yours is spraying after the spin, so this suggests the timer is at fault. Try changing it out and see if that does not fix things. If you buy from this site and the new part does not fix the problem you can return it.
