Spowers
Whirlpool range when you touch the bake panel burner, the broiler burner comes on also. What is causing this problem.
Here are your parts.
Parts for Whirlpool RS675PXGT15 Range - AppliancePartsPros.com
Sorry but I do not understand, could you explain it in different words.
Also what exactly is the problem?
It is normal on most units for it to use the bake and broil elements during preheat and bake modes. This provides a more consistent temperature profile in the oven.
:slight_smile: [QUOTE=denman;801648]Here are your parts.
It is normal on most units for it to use the bake and broil elements during preheat and bake modes. This provides a more consistent temperature profile in the oven.[/QUOTE]
The bake element was on and all of sudden the broiler element came on and burned the cake that was baking, both elements were on at the same time
when only the bottom element was supposed to be on. thank you
Sounds like the control board (item 3 in the Control Panel Parts) needs replacing.
RS675.pdf (8.4 KB)
