spins fast sounds like an airplane noise
We have noice that our washer is spinning so fast it sounds like an airplane engine taking off. at times when the spin cycle is done its still wet.
:confused:
Most likely the cause of the problem is the drain pump bearing.
Lift the washer form the front, remove the belt and check how free the pump pulley is moving.
