Spinning violently
Brand:Samsung
Model Number:WF42H5000AW A2
Main Symptom:SPINNING VIOLENTLY
What happens & when:spins out of control I checked the inner tub as you can see in video and it feels tight I changed all four shocks from Samsung
So I like to know what else can cause the imbalance other than the spider arm in the back before I order it and take it apart Please
Thank you
Parts or tests already tried: four shocks
Photos / video link:https://youtu.be/4ILJoTv_Vx8?si=gavRt76pHLvZOWqe
Hi Luckyduces22, thank you for your post.
Based on the video, it appears that the spider shaft or the drum assembly may be bent or out of alignment. When that happens, it typically leads to excessive movement or wobbling during the spin cycle.
In most cases, repairing this condition involves replacing the rear tub and bearings, the spider shaft, and possibly the spin basket/drum, depending on the extent of the damage.
Could you also check if there is an REV number listed on the model tag? That revision number can be important when identifying the correct replacement part numbers for your specific version of the appliance.
