Main Symptom: spin won’t go into high mode What happens & when when the spin cycle starts as it goes faster and gets ready to kick in to the fast high mode it shuts down and restarts. It does this like 3 times and then stops. The clothes still have to much water left in them.
Parts or tests already tried: a new control board
Most washers will not go into high speed spin if there is still water present in the tub. Do you hear the drain pump come on? does it pump all the water out?
Check the belt, make sure the latch is locking the lid. Try running it without a load; an unbalanced load will do the same thing. It will go back and forth, trying to balance the load, and then time out.
