Speed Queen Washer
Brand:Speed Queen
Model Number:AWN412SP111TW01
Main Symptom:Slow Hot Water Fill
What happens & when:Hot water comes out slow Cold water works fine
Parts or tests already tried: Cleaned all screen filters. Put on new mixer inlet valve. Part number 201468p Still slow hot water fill. Any suggestions?
It would be recommended to make sure that the water flow into the unit is good. With the unit having a new valve then it should flow at a good rate as long as the water to the unit is good.
