has a plastic lint ring on the inside of the tub up at top
is it possible to remove this so it can be cleaned?
All of the dirk clothes come out with a chalky smear all over them
I would recommend to use the Washer Magic cleaner instead of taking the washer apart. It works very good (I used it at home) and if you will use it periodically, your clothes will always smell fresh.
