Speed Queen washer repair question code ER FL
Brand: Speed Queen
Model Number: awne82sp113tw01
Main Symptom: Stops filling
What happens & when: It happens only when tub is almost full and set on large load. It takes 11 minutes to fill on small load. Small & medium loads work ok except it takes a long time to fill either one. Water pressure is 60 psi. One year old house and hoses. Screens at fill valve are clean.
I removed the hoses at the washer and both hot and cold have a very strong flow when the valves are turned on. I suspect the fill valve is the problem. I would like to find a video on how to access the fill valve.
Error Code (if any): ER FL
Here is a link (https://www.youtube.com/watch?v=K9zyc8oC_9I) to a video on our site on YouTube showing how to access and replace the fill valves ( 205547P Washer Water Inlet Mixing Valve | Genuine Speed Queen OEM In Stock ) on a similar model washer. The procedure for model AWNE82SP113TW01 is very similar and can be used as a reference for your repair.
