Brand: Speed Queen
Model Number:SFNNCRSP115TW02
Main Symptom: Error CodeEd12
What happens & when: happens every few days Reset by unplugging and happens again
Error Code (if any):Ed12
Brand: Speed Queen
That is a voltage issue. It is sensing a voltage that exceeds 120 volts AC, Check you outlet voltage at the plug, if it is good, replace the control board.
Hello,
Can you send me the part number for the control board on this model?
Thanks!
Honestly, You might want to contact speed queen on this one, The parts I see are over a thousand dollars. i want you to get the right part. If they give you a part number, we can see how that stacks up with out pricing.
