Speed Queen dryer not heating pls help
Brand:speed Queen
**Model Number:**ADE3SRGS173TW01
Main Symptom:not heating
Tested element and fuses / sensors
Found the timer was shorting out the H orange wire
I see several used timers on eBay but looks like new ones are different and you have to rewire the whole dryer ..
This doesn’t look like a DIY job ..
Suggestions ?
Thank you
Yeah it looks like you have to change the harness and timer because of a new vendor!D519030 Timer Conversion Kit (Rear No-Signal) | Genuine Speedqueen OEM In Stock
Trying to find a good used one
How hard is it to rewire the new one ? I’ve heard it’s a 6 hour job
Don’t think it would take that long.Here is the wiring diagram and service bulletin. Of course if you get the kit it will come with a new wiring diagram!
FB22-15R2 Service Bulletin Replacement Kits for Kingston Dryer Timers.pdf (190.0 KB)
Speed Queen ADE3SRGS173TW01 Dryer Wiring 515258.pdf (708.0 KB)
Where can I get a copy of the installation instructions ?
Thx
