Kenmore Soft Touch
MODEL/STOCK NO.
86864100 68641
I tried to clean my dryer out. I removed the outer back cover and then tried to remove the cover off the lint trap and fan. It was stuck with some foam glue material. I pulled off part of it thinking it was lint and then stopped. Is it okay to open this up to clean it out?
My other problem is that I tried to install a new vent and when I opened the dryer up there was a white and purple wire connected to a plastic black shaped circle laying inside the body.
I tried installing the vent and I did a test run and there were sparks. I think the white and purple part might of hit the metal vent. I turned off the dryer and unplugged it.
I’m wondering where this white and purple plastic part is suppose to sit in the dryer.
