Brand: Bosch
Model Number: 189010
Main Symptom: One of the outputs not working
I have diagnosed my Bosch 189010 6 point Spark Module and determined that point #6 is not working. In my Thermador cooktop, it uses points 1,2,5,6 (the input cable has wires for all 6 points but there are only wires attached to outputs 1,2,5,6). #6 is not firing.
Since there are no wires on the outputs of 3 and 4, can I remove the input wire at SW4, move the input wire at SW6 over to SW4, and then move the output wire at S6 over to S4? Not sure if the circuits are the same and interchangeable.
Photos / video link: 189010.jpeg
