Would anyone know if a spanner wrench is needed to remove inner tub from an older Maytag? If so, would you know a part number, I have purchased two and neither seems to fit ?
thanks,
dwane1
thanks,
dwane1
This tool is used in conjunction with the spanner wrench that has the three drive pins, in the removal of the tub seal.
Thanks magician59, I have not tried these, will order and try.
dwane1
