Seams to be working fine but. It is getting hot around the freezer door seal surface. And it may be running all the time. :eek:
OK, I found a video on You tube that said it is the “yoder loop” and either the condenser is dirty or the fan isn’t working. So I opened up the back and checked. I found the fan working fine and cleaned the condenser good, I didn’t think it was all that bad to begin with. I put it all back together and it is still getting hot. Any help out there???
Over 200 hits and no help!!
What am I doing wrong??? ![]()
Perfectly normal. The yoder loop is to prevent condensation from building around the door seals.
[QUOTE=cbmserviceguy;897592]Perfectly normal. The yoder loop is to prevent condensation from building around the door seals.[/QUOTE]
Yes I agree with you about what the Yoder Loop is for, however with all due respect, I don’t believe it was ever as hot as it is now right at 117 deg. F all the way around the door. And it seem to be running a lot. ![]()
If it’s running all the time AND has good condenser temp, it has an air leak somewhere. Check all your door seals to make sure they are tight. Newer refrigerators do run a lot more than older ones. The new inverter driven compressors focus on a low energy demand, marathon mentality low cool system where the older ones were more of a hot rod drag race style. 117 degrees is not out of the norm.
[QUOTE=cbmserviceguy;897612]If it’s running all the time AND has good condenser temp, it has an air leak somewhere. Check all your door seals to make sure they are tight. Newer refrigerators do run a lot more than older ones. The new inverter driven compressors focus on a low energy demand, marathon mentality low cool system where the older ones were more of a hot rod drag race style. 117 degrees is not out of the norm.[/QUOTE]
Do you know or is there a way for me to tell if this one has an inverter driven compressor? ![]()
Compressor Mod.#5304475140
Fridge. Mod.# FRT21HR6AW0, S/N LA13305137, Mfg. Date 8/01.
Thanks,
Jake
That unit is not inverter driven. Have you checked temps inside? Colder than it should be in the freezer? Door seals all good? Any defrost issue?
Freezer -5, Fridge 35. Defrosts fine. A dollar bill is consistently snug around both doors. I had a fridge once that got wet from condensation on one side of the the freezer door. It turned out that the seal was bad, this one is dry all the way around and so is the fridge. :rolleyes:
Sounds like everything is on the up and up. I would try to pay attention to how much it runs. It could be that you just happen to be around it when it’s running and it’s shut down when you aren’t around?
I will try to monitor that, and let you know. What is the coldest that the freezer should be set at?
Thanks,
Jake
Freezers generally run around 0 degrees give or take a bit. Fresh food should be about 37. Hope it all works out for ya!
