something between drums like a coin spinning around
I was looking for a video to see if I can remove the inner and outer drums because there is something loose when you turn the drum. Sounds like when a coin or something metal is loose in the wash but this is coming from elsewhere when you spin the drum. It makes an awful noise when on spin cycle so I stopped the machine.
Thanks,
Bob
Whirlpool will no longer let us access their on line tech library. I suggest you contact Whirlpool and as an owner see if they will provide you with a service manual. If not, try going on line and see if you cannot down load one for a nominal fee.
It may be a rear bearing problem in which case replacement of the machine is the best decision money wise.
