Some Lights are on but wont start
there is power to the unit..when i push the “normal” button the light turns green, but when i push the “start” button nothing happens except the “normal” light blinks once…the unit is not locked… when i push the the High Temp and Energy Save button alternately a few times all the lights turn on..I then push cancel and all the lights turn off…all other lights light individually when pushed except the Start light
Check the door switch(es) and make sure it’s properly engaged when the door is latched. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDP01FLSS1 Dishwasher | AppliancePartsPros.com
Here is the Tech sheet.
The door seems to be working…is there a way to make sure the latch is engaged when the door is closed…is there a way to check it using the touch pad
The only way to verify it is to test it with an Ohmmeter.
i will check it..lets say it works…what could be the problem?
Lets do one thing at a time.
Thank you Gene. I appreciate your help. i have the ohmmeter, but dont how to test..do i have to remove a part of the panel to do it…or is there a way to do that without removing any of the screws…if i have to remove panel please talk me thru it :slight_smile: I can unscrew the screws around the inside of door easy enough but how the rest come apart.
The door has to be taken apart. You can find the instructions in the Service manual.
thanks i will let you know how that goes
Gene…ran out of time and hd to call a repair guy…turns out it is the door latch…thank you so much for your help
