Some buttons on my range don't work
Of the 6 buttons on the left only the Broil button works. Most of the number pad buttons are also not working. Is there a trouble shooting procedure, or do I just need to replace the touch pad? (Membrane?)
Parts for Whirlpool GW399LXUS04 Range - AppliancePartsPros.com
The touch pad is the most likely culprit.
Could also be the control board.
First I would unplug the unit for a couple minutes to see if it will reset.
Next I would try the below.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
Next would be to check the keypad.
Unfortunately manufacturers do not publish the pin-outs for range keypads so checking it is difficult. It can be done but you need experience at this type of procedure.
Note that if you order from AppliancePartsPros they will let you return the part if if does not fix the problem.
Please see their return policy.
