(SOLVED) Amada (Whirlpool) ADB1100AWW3 intermittent spraying
Hello everyone.
My washer will spray correctly in some cycles and not durring others.
The filters, spray arms, and everything I can check are clear of blocks.
I am suspecting that the control board has gone bad but I dont have the experience or Tools to check it.
Could a faulty control board be a problem in this case?
Thank you for reading and any help.
Amada model ADB1100AWW3
Control board model W10817282 (I believe)
Update for anyone wondering:
I did replace the control board. It was not the problem.
My next move was to remove and dissasemble the circulation pump. Once it was taken apart I found and removed a small amount of hair wrapped around the shaft of the impeller. The rest of the unit was fine.
I reinstalled the pump and as of now the washer is working. Hope it stays that way.
