Solenoid plunger problem
I recently purchased and replaced the solenoid and drain valve arm (& seal) on my GE dishwasher However, the new solenoid plunger keeps popping right out of the solenoid when it tries to drain…Any suggestions?
The bracket is probably bent downward, bend it up so the plunger does not come out. What part# did you use?
I ordered part number #AP2039683 - solenoid drain kit
When it goes into drain, the solenoid arm does go dowm into the solenoid right?, and after drain it goes back up?
Yes, it goes down - but after drain it goes back up and flies out of the solenoid and lands on the floor
Any way you can take a pic, and attach it, you must have assembled it wrong, and without seeing it, I’m not to sure I can tell you what is wrong
Did you take out the shaft that goes into the plastic housing of the motor assembly?
Yes because I also replaced the pump drain valve shaft seal…
I think that is your problem, If you don’t get that shaft back in through the flapper assy inside the pump assy, than this will happen. If you want to try to get it back in properly, you will need to remove the motor/pump assy and do it this way. If you can’t get it in, and I never have been able to, you will need to install a new motor/pum assy.
Great… will check it out. Thank you for the help.
Upon further thought - does this mean you would have to replace the whole motor/pump assembly anytime you replaced the pump drain valve shaft seal - which you have to replace by taking off the shaft - and by the way, the seal is a part that is suggested to also be replaced when you replace the drain solenoid…
Normally you don’t remove the shaft when replacing the seal, otherwise you run into this problem, and now you may have to replace the pump/motor, unless you can figure out a way to get the shaft back into the drain flapper.
So then how do you get the seal on if you don’t remove the shaft?
There is a ring on the shaft you take of, you can then slide off the old seal and put the newone on, then put the lock ring back on
