Solenoid, or Potentiometer
Like everyone else, I am having problems with my left front burner. I get spark, but no gas. I replaced the valve, and it worked for a while until I tested the XLO feature, then it went dead again. I am getting tired of taking this thing apart, and would like to just fix it for good. Which is the most likely culprit? Thanks in advance for your help.
Perform the troubleshooting as described in the attached instructions.
Here are the breakdown diagrams and Replacement parts for THERMADOR RDSS30 S/N 9707 & UP | AppliancePartsPros.com
XLO burners troubleshooting.pdf (817.2 KB)
