Soggy clothes
My maytag MAV5920EWW does not remove all of the water from the clothes after the final spin cycle. The clothes come out soggy. I have replaced the drain pump, thrust bearing (via the kit which includes the pulley), snubber ring, brake rotor and brake spring. Clothes still come out soggy. Additional running on just the spin cycle still does not remove all of the water.
Hello,
Check the belt. Check between the tubs for a foreign object.
Here are the breakdown diagrams and Parts for Maytag MAV5920EWW Washer - AppliancePartsPros.com
