Brand:Maytag Model Number:MHW8630HC0 Main Symptom: Softener dispenser not receiving water What happens & when: All cycles, detergent and bleach dispensers receive water
Error Code (if any): No error code
You will want to open the dispenser and check to see if there is any clogging in the dispenser housing. If there are no clogs then the water cold water valve would be the most likely cause for this issue. W11688994 Washer Water Inlet Valve | Genuine Whirlpool OEM In Stock
Replaced the dosing pump. Softener drawer still not receiving water Would it be a control panel issue? Not worth any expensive repair just to get the fabric softener working.
