Brand:Whirpool
Model Number:GHW9400SU0
Main Symptom: Soap dispensor not emptying
What happens & when: After wash some soap and softener left in dispensor. Unit is clean. No error codes. Motor is turning actuator thru cycles.
Took entire unit apart. Cleaned dispensing holes as best I could (used tooth pick and dental pick) then flushed unit. Everything looks good. Now soap and softener dispensor empty but at end of cycle bleach section is full of water.. Nothing is binding up in the pop section.
