Soap dispenser won't open
[I][FONT=Times New Roman][SIZE=4]My Dish Washer soap dispenser will not open automatically. The work-around is to open it mamually. What might be the reason and what part (part no?) needs to be replaced?
In addition, I notice minor leak because a cut at the tail end of the drain hose. Is this a common and/or universal part that I can buy from local Plumbing supplier? How do I repair it or must I replace the hose?
Thanks in advance for your help…
[/SIZE][/FONT]
[/I]
Has anyone found that replacing the dispenser itself resolves this. In my case, the gasket seems a bit worn and I will probably do the replacement of the door and the dispenser dish, unless someone has a better idea. I am a bit reluctant to start replacing any of the other parts, as it all looks a bit too complicated for me. Model No: mdb.7100awb. blarney
[quote=chwu999;22073][FONT=Times New Roman][SIZE=4]My Dish Washer soap dispenser will not open automatically. The work-around is to open it mamually. What might be the reason and what part (part no?) needs to be replaced? [/SIZE][/FONT]
[SIZE=4][FONT=Times New Roman]In addition, I notice minor leak because a cut at the tail end of the drain hose. Is this a common and/or universal part that I can buy from local Plumbing supplier? How do I repair it or must I replace the hose?[/FONT][/SIZE]
[SIZE=4][FONT=Times New Roman]Thanks in advance for your help…[/FONT][/SIZE]
[/quote]
