Soak light is flashing, dishwahser will not start
Cancel doesn’t do anything either.
When unplugged and plugged again, soak light comes on flashing. After hitting few keys, normal starts blinking again along with the Soak/Scour light. I had this problem before, and i think i tried some combination (rinse-dryheated) or soemthing like that, but it didn’t do trick this time.
Sounds like it may be a stuck key.
Check the keypad out with a meter see the tech sheet.
You may also want to try the diagnostics.
If the keypad checks out then you may want to try the following though usually it only works for open keys.
Connector Cleaning
Unplug the unit
Open it up
Clean the edge connector.
