Brand:GE
Model Number:JB620DF2BB
Main Symptom:Hot burner light stays on
What happens & when: everything else is working fine
Brand:GE
hi mirekp17, TEmpERATuRE LImIT/HOT LIGHT SwITCH The Temperature Limit/Hot Light Switch performs two functions: 1. Turns on HOT LIGHT when the glass surface above the heating unit has reached 150°F. The hot light will remain on until the glass surface above the heating unit has cooled below 150°F (even after surface unit switch has been turned off). 2. Detects when glass temperature above a unit has exceeded its limit of approximately 1031°F and disconnects power to that unit. When glass temperature cools below 1031°F, the unit will turn back on. The temperature limit/hot light switch cannot be calibrated. or a short somewhere in the control board.
