Smoke from starter/plastic burning smell
smoke started coming from under frig
unplugged took back cover off smoke coming from starter
do I need to replace starter and compasiter relay both
Yes, use part #241707701 Check the compressor pins for molten metal. If there, use a dremel grinder to fix.
