Smelly water has to be drained often
Brand:LG
**Model Number:**WM3570HVA
/01
Main Symptom:Smelly water needs to be drained from the bottom by the filter
My washer has a bad smell that only leaves when I drain the hose next to the filter. I have to drain this after every wash or so.
What do you think the issue is?
If there is not a seal on the drain hose at the stand pipe, the washer may just need to be put through a cleaning cycle or two. However, if the drain hose is tightly fitted into the stand pipe and there is only a small air gap, drain water can back up into the washer if there is a clog.
