Samsung Frig
model # RF29A9071SR/AA
Small bite ice tray cracks
The plastic tray on the small bite ice assembly continues to crack and fail. After the 3rd one failed, I believe I now know what is happening. The tube that directs the water into the tray- its freezing up causing a large chuck of ice. When the tray is rotating to dump the ice, its hitting that chuck of ice and cracking. It seems that after the water is done filling up the tray, there is water still running in the tube. This seems to be a known issue but I have not seen a fix. I would appreciate your thoughts. Thanks
