Brand: GEG
Main Symptom: Extremely slow water dispensing
My GFE28GYNGFS refrigerator is EXTREMELY slow to dispense water and makes ice slow as well. I replaced the filter several times and checked the supply line. Any assistance is greatly appreciated
Try removing the filter and put the bypass in. Check to see if the water flow improves. If it does then this will be a filter head that is faulty and would need to be replaced.
Thank you, do you know the part number for the bypass plug? I do not believe I have one.
Thank you! Last question: if it is the filter head, what part number would that be?
Thank you for the assistance!
There seems to be no difference with the bypass in… I timed filling a 16 oz glass and both took approximately 1 minute to fill.
This issue sounds like it would be caused by a faulty filter head that is the problem.
