I have a washer that wont spin or spins very slowly I replaced the brake assembly as it was making a loud screeching noise when it stopped that noise is fixed however now it wont spin and ideas? its a maytag
The lack of spinning is probably because your brakes are not releasing. It may be that they did not go in correctly, which you can check, but more likely is you need to replace this part.
