Slow Leak from somewhere under Fridge
My Kirtchen Aid has a very slow, subtle leak from under.
Ice maker, still works, Water dispenser still works. Fridge still works perfectly except for little leak that seems to be filling the drip tray daily.
Dwinx
By drip tray i’m assuming you put a drip tray underneath or are you talking about the evap/defrost pan that’s in the unit?
LOL okay yes that thingie majig. (the evaporation/defrost pan)
Dwinx
The evap/defrost pan it’s normal to have water leaking into it that’s what its designed for when it finishes defrost cycle. If it’s overfilling over the top of the pan or more then 3/4 full of water depending on the size of the pan without the condenser fan drying it out regularly then you got a problem.
We shut off the water to the dispenser & it’s been fine. The leak is related to the water dispenser.
Dwinx
I’d like to get the dispencer & ice maker working again. Please advise what steps can be taken to eliminate the leak
Dwinx
