Sloinoid Hums..not Draining
Stored this unit 2 months then installed, Now the motor hums but does not pump. Gets REAL hot as well.
How the heck do I pull the darn pump to get to impeller. My Lady is nearly postal..HELPPPPPPPPPPPPPPPPPPPPPPPPPPP.
For the record…it’s not the hose or drain line…both clear. I also checked the screens and the inner sump area for junk…Crikey!!!:eek:
Thanks in Advance..I might survive another day if someone could help me…
Mark
Chestertown MD
Hey Folks…anyone Care Too Help???
Well guys…guess you pro’s knew I would search the old posts…THANKS for well..not replying.
The solution was as follows:
Take 1 friggin screw out of the right side facing the front…rotate the JAMMED motor…put all the covers back on..runs like a charm. Food must have jammed the pump motor. The selinoid was humming trying to push motor I guess. Great washer btw…
