Rear right element is not turning on, I would like to know is the infinitive switch or the element pls
Hi Raul,
The problem can be a bad infinite switch, a bad heating element or a bad wiring for this burner. You have to check them for continuity to determine which part exactly is bad. The Tech sheet with the wiring diagrams is attached to the reply.
Here are the breakdown diagrams and Replacement parts for Whirlpool KESA907PSS02 30" Slide-In ELECTRIC OVEN CONVECTION | AppliancePartsPros.com
KESA907.pdf (422.8 KB)
