I have a Jennair JES9800AAB slide in range, and one of the burners is not working. A few months ago the light indicating On stopped working properly (would show on when clicked off, would show off in some positions), then a few weeks ago I turned the switch to Low, the burner went to full high and shut off. That burner has not worked since.
I would like to pull the control panel and check the switch, but there are two screws obscured by the countertop. I am looking for advice on how to release the range to pull it out about 1 inch. I understand one of the legs may be secured to an anti-tip bracket, and I may need to disconnect the air duct. Should I expect any screws between the range and the cabinets it’s installed between?
