Single Wall Oven (True Temp)
GE True Temp wall oven - Several oven touch buttons (BAKE, BROIL, COOKING TIME, DELAY START) do not register/work on the electonic display panel while other buttons (SELF CLEAN, OVEN LIGHT, TIMER, CLOCK, START, CLEAR/OFF) do register and work. All buttons worked yesterday but not today. I tried turning off/on the circuit breaker but that did not help. Any ideas what might fix the situation? Is there a “reset” switch anywhere that may have tripped? THANK YOU.
I cannot find info on this unit.
Most keyboards are the matrix type in other words a number of keys use the same return line could be this line/wire/track is just dirty. That is why it is intermittent.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
[quote=denman;280818]I cannot find info on this unit.
Unplug the unit
Open it up
Reconnect everything and give it a try.[/quote]
Denman was right on the money - it apparently was a dirty or loose connection. All the touch controls appear to be working again - THANK YOU!!!
