Our built-in electric single oven went dead after we tried self-clean. The door was locked and the control panel is blank (no power). All previous posts of the similar issues that I found are referring to double oven models. Could anyone please help to check/confirm if my model RBS305PDB16 has thermal fuse in the control board? I don’t see a fuse similar to AP3110028 in the board.
In addition, I noticed that one component of “C21” in electric board was burned out. I could not figure out what it was. Was it a Capacitor or a fuse? Do I have to replace whole electric board?
[COLOR=“RoyalBlue”]All previous posts of the similar issues that I found are referring to double oven models.[/COLOR]
They are basically the same.
[COLOR=“RoyalBlue”]Could anyone please help to check/confirm if my model RBS305PDB16 has thermal fuse in the control board? I don’t see a fuse similar to AP3110028 in the board.[/COLOR]
It would be in a wire going to the board. If you do not see it then odds are your unit does not have one.
This unit does not show one but I am hesitant to say for 100% that it does not as often they do not show up on wiring diagrams.
Note it may have a different color shrink wrap so you may just see a bulge in the wire.
[COLOR=“RoyalBlue”]In addition, I noticed that one component of “C21” in electric board was burned out. I could not figure out what it was. Was it a Capacitor or a fuse?[/COLOR]
It will be a capacitor.
[COLOR=“RoyalBlue”]
Do I have to replace whole electric board?[/COLOR]
Yes.
Manufactures do not publish board schematics so they are difficult to repair.
The thermal cut-out will cut power to the elements but the control board should still run.
Sounds like at the very least you need a new control board.
I have checked the wires going to the board. I guess it does not have one.
[FONT="]The cut-off thermostat on the back of oven might went bad as well, but I would start with the control board issue first. I have ordered a new control board and will see how it goes.[/FONT]
if you don’t jump out the thermostat in the rear first, you could be wasting your money!!! I have only been repairing appliances for 30 years!! Good Luck!! Tom. ApplianceEducator.com
