Single Burner out on Glass Top Stove
One of the large burners has stopped working on my glass top stove. What should I check first?
super capacity 465 is not a model number, pull out oven drawer ,where drawer meets frame there is a sticker on frame that says model number+ serial number
Was there an answer to this post? I have the same problem on a 2002 Amana glass cooktop stove.
I have an Amana glass stove top (Model AK2H30HR)which just has a burner that no longer works. I am about to order a replacement “7” ribbon element" and since I will have it apart I am also going to order a new “limiter” for the burner. Are chances good that that will fix the problem? Thanks
[QUOTE=car62;82226]Was there an answer to this post? I have the same problem on a 2002 Amana glass cooktop stove.[/QUOTE]
badabing and car62,
If you are looking for professional advice then you have to post the complete model number of the product and most possible description on the problem.
[QUOTE=donburrer;82421]I have an Amana glass stove top (Model AK2H30HR)which just has a burner that no longer works. I am about to order a replacement “7” ribbon element" and since I will have it apart I am also going to order a new “limiter” for the burner. Are chances good that that will fix the problem? Thanks[/QUOTE]
You do not have to order a new limiter because it comes with a new element. I would check for continuity the infinite switch for this burner.
Here are the breakdown diagrams and Replacement parts for AMANA AK2H30HR | AppliancePartsPros.com
Thanks, Gene. I can check the continuity of the switch. However, the “burner on” indicator light does go on. Is it a two or a single pole switch? Don
It is a two pole switch.
