The ice dispenser door won’t close. Thanks for any help.
Gene
Gene,
[LEFT]Use a screwdriver to unlock the tabs at the bottom of the dispenser control panel. Slide the bottom out and down.[/LEFT]
Disconnect the wiring harness connectors.
Put the dispenser control panel aside.
[LEFT]Remove the four screws in the door dispenser housing.[/LEFT]
[LEFT]Slide out the housing and disconnect the target switch and dispenser light connectors.[/LEFT]
[LEFT]Spread out the locking tabs and remove the switch.[/LEFT]
[LEFT]Push the chute duct door locking tabs back and raise the assembly above the locking tabs.[/LEFT]
[LEFT]Push the lower armature locking tabs (under the assembly) back and lift up the entire assembly.[/LEFT]
[FONT=Times New Roman][FONT=Verdana][SIZE=2][COLOR=#000000]Check all parts shown on the attached diagram.[/COLOR][/SIZE][/FONT][/FONT]
[FONT=Times New Roman][FONT=Verdana][SIZE=2][COLOR=#000000]Post your findings.[/COLOR][/SIZE][/FONT][/FONT]
[FONT=Times New Roman][FONT=Verdana][SIZE=2][COLOR=#000000]Gene.[/COLOR][/SIZE][/FONT][/FONT]
