My Samsung front load washer has excessive wobble during spin cycle to where the machine shuts off then restarts the spin cycle again whether the load is balanced or not. I bought and replaced the 4 bottom shock dampeners from your website with no success. The machine is level. Not sure if this is a mechanical or electrical issue. Debris filter is clean and drains normally. Any ideas or similar experiences?
Two possibles here.
- the support arm (spider arm) shaft assembly which is part ID 7-4 on the parts breakdown.
Samsung DC97-16509C Assy Flange Shaft;grace, - AppliancePartsPros.com - it may be your bearings on the drive shaft are bad.
Parts #: 6601-002516 rear bearing (not available even thru google search)
Parts #: 6601-002632 front bearing (not available even thru google search)
Parts #: DC62-00156A seal
[QUOTE=brobriffin;901831]Two possibles here.
Parts #: DC62-00156A seal[/QUOTE]
Thank you for the reply and information.
