When my parents died I took their washer. I don’t how old it is. I called “Mr. Appliance” and was told it could be 29 years old and that parts were still available. I really question that. Anyway, the machine leaks–sometimes alittle, sometimes alot. Plus now it does not spin all the water out. Sometimes there is two inches of water, sometimes bubbley foam only. Is the machine worth fixing ? I really like it but maybe something else will go wrong next if I do fix it.
I would pull off the front panel and check where the leak is, probably from the tub. If so, it probably is not worth fixing.
